Hello, I’ve just installed Grafana on a Debian box running an OpenHAB setup, there is an existing MySQL database with metrics in it, and I wish to graph these. I have set up MySQL as a datasource and Grafana says it’s fine and it can log in.
When I create a graph in a dashboard and click on Edit in the title, I get to the “Metrics” tab, select the MySQL data source, go to the first line below (with “A” and a non-functional downward-pointing arrow to the left), click “Add Query”. This then changes to “Format As”. The next box is “Time Series”, and the box after that is “Show Help”.
If I change “Time Series” to “Table”, I get an error:
Error 1064: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '<time_column>) as time_sec,
<value column> as value,
<series name column> as' at line 2
I was expecting some kind of query editor so I can get the relevant data out into a timestamp and a value, but I do not get that. I have no opportunity to enter any SQL, but the help files and videos I’ve watched seem to suggest that I should get that.
I’m running 4.5.0 from the Grafana repository.
