Hi, after I noticed that (issue described below), I tried another versions 8+ until 8.5 but I got the same issue.
I can’t update to latest version of grafana.
Grafana: 7.5.16
OS: Windows 11
Delete fields of select or where conditions
Clicking on Column name or Macro label to show remove option
What happened?
At first time nothing is render, only a line. If I inspect element on browser I can see an html UL element rendered without content.
After that I need click twice, first to close drop menu and then one more time to reopen, so the content of drop menu appears correctly and I can delete select fields or where conditions
See delete option from drop down menu at first time.
Did you receive any errors in the Grafana UI or in related logs?
There is no error in the Grafana UI or in logs
