Afther update to Grafana v8.02 it does not hide the columm when i disable it in the quey editor.
Before when i disable it it also did not schow the columm.
Can i hide it somwhere else ??
Grafana on raspberry
Hi @nvbgm
Are you using that table panel? Can you attach a screenshot of what your query returns and what you are trying to achieve? Thanks!
