Hello all,
I need to obtain a daily aggregation of the avg and max (peak) CPU utilisation per node/instance. I’ve done some research and it seems these are the correct queries:
Avg:
100 - (avg by(instance) (rate(node_cpu_seconds_total{mode="idle",instance="$node"}[2m])) * 100)
Max:
max_over_time((100 - (avg by(instance) (rate(node_cpu_seconds_total{mode="idle",ins
Here’s how I defined it in Grafana:
Mostly, I’m looking for confirmation that these are correct and will result in the required data because they do not seem to align with what a different monitoring system (which I do not control produces).
It’s worth noting that I based my queries on the data provided in Promql difference between max and max_over_time
In case you’re familiar with Oracle Enterprise Manager, the query made to generate the report there is:
select target_name, sum(average) CPU_AVE, sum(maximum) CPU_MAX, to_char(ROLLUP_TIMESTAMP,'YYYY-MM-DD HH24:MI') TS_ROLLUP
FROM SYSMAN.MGMT$METRIC_DAILY
WHERE ROLLUP_TIMESTAMP > (sysdate -30) and target_name like 'servername'
and (
upper(COLUMN_LABEL) like upper('%CPU in User Mode%') or
upper(COLUMN_LABEL) like upper('%CPU in System Mode %')
group by target_name,to_char(ROLLUP_TIMESTAMP,'YYYY-MM-DD HH24:MI')
order by TS_ROLLUP
Thanks in advance for any advice,
