Basically I want to show a table for all hosts (aws ec2) with ave/max usage of cpu/memory over x days, days being a variable defined.
Using following record rules:
rules:
- record: node_cpu_usage_seconds_total:rate1m
expr: rate(node_cpu_seconds_total{mode="idle"}[1m])
- record: node_memory_MemNotFree_percent
expr: 100 - (100 * node_memory_MefFree_bytes / node_memory_memTotal_bytes)
I have written 4 queries, but 1) they are giving misleading data and are very slow…![]()
Query to get average cpu isage over x days
100 - (avg by(instance) (rate(node_cpu_seconds_total{mode="idle"}[${days}d])) * 100)
To get max CPU usage
max( 100 - max_over_time(node_cpu_usage_seconds_total:rate1m[${days}d])*100 ) by (instance)
To get Average Memory
100 * (1 - ((avg_over_time(node_memory_MemFree_bytes[${days}d]) + avg_over_time(node_memory_Cached_bytes[${days}d]) + avg_over_time(node_memory_Buffers_bytes[${days}d])) / avg_over_time(node_memory_MemTotal_bytes[${days}d])))
Max memory
max(node_memory_MemTotal_bytes - max_over_time(node_memory_MemFree_bytes[${days}d])) by (instance)/(1024*1024*1024)
What may be wrong? How to improve performance?
Thanks in advance
-S
