I have installed Grafana version 10.4.2, Prometheus 2.47.2, and Blackbox Exporter 0.24.0. I want to monitor a website, why can’t I find probe_http_status_code ?
this is my config blacbox.yml
this is my config prometheus.yml
Hello @iwan2323
I assume you have some targets in your static_configs: in your prometheus.yml.
If not please be sure you correctly configured your different targets.
Can you share a copyable version of your configuration? Using “```yml” for good format.
Regards
Hello @codi639
Thank you for your response, I really appreciate it.
Below is an example of my prometheus.yml config targeting a website
Regards
Hey,
With your new prometheus file (this is why I wanted you to write your code, but it’s okay I did it myself):
prometheus.yml:
scrape_configs:
- job_name: 'blackbox'
metrics_path: /probe
params:
module: [icmp, http_latency, http_2xx_example, probe_http_status_code]
static_configs:
- targets: ["https://example.com"]
labels:
group: Website
relabel_configs:
- source_labels: [__address__]
target_label: __param_target
- source_labels: [__param_target__]
target_label: instance
- target_label: __address__
replacement: 'localhost:1234'
You call a modules probe_http_status_code but in your actual blackbox.yml you use a http_status_code. I’m not very used to this, but I think this might be an issue?
Can you try to change your blacbox.yml file:
modules:
http_2xx_example:
prober: http
timeout: 5s
http:
#preferred_ip_protocol: ip4
valid_http_versions: ["HTTP/1.1", "HTTP/2.0"]
valid_status_codes: []
method: GET
http_post_2xx:
prober: http
http:
method: POST
probe_http_status_code: # Adjusted module name to match Prometheus configuration
prober: http
http:
method: GET
Let me know if I’m wrong!
Regards
Hey @codi639
here’s my file blackbox.yml
modules:
http_2xx_example:
prober: http
timeout: 5s
http:
# preferred_ip_protocol: ip4
method: GET
http_post_2xx:
prober: http
http:
method: POST
probe_http_status_code: # Tambahkan modul ini
prober: http
timeout: 5s
http:
method: GET
tcp_connect:
prober: tcp
pop3s_banner:
prober: tcp
tcp:
query_response:
- expect: "^+OK"
tls: true
tls_config:
insecure_skip_verify: false
grpc:
prober: grpc
grpc:
tls: true
preferred_ip_protocol: "ip4"
grpc_plain:
prober: grpc
grpc:
tls: false
service: "service1"
ssh_banner:
prober: tcp
tcp:
query_response:
- expect: "^SSH-2.0-"
- send: "SSH-2.0-blackbox-ssh-check"
irc_banner:
prober: tcp
tcp:
query_response:
- send: "NICK prober"
- send: "USER prober prober prober :prober"
- expect: "PING :([^ ]+)"
send: "PONG ${1}"
- expect: "^:[^ ]+ 001"
icmp:
prober: icmp
icmp_ttl5:
prober: icmp
timeout: 5s
icmp:
ttl: 5
and this is my prometheus.yml
scrape_configs:
# The job name is added as a label `job=<job_name>` to any timeseries scraped from this config.
params:
static_configs:
- targets: ["https://www.myweb.com"]
labels:
group: Website
relabel_configs:
- source_labels: [__param_target]
replacement: 'localhost:9119'
Do you have any logs from blackbox? If yes please share it.
Can you try to reach http://localhost:9119/metrics and tell us if any metrics related to the probe_http_status_code?
this is my http://localhost:9119/metrics
# HELP blackbox_exporter_build_info A metric with a constant '1' value labeled by version, revision, branch, goversion from which blackbox_exporter was built, and the goos and goarch for the build.
# TYPE blackbox_exporter_build_info gauge
blackbox_exporter_build_info{branch="HEAD",goarch="amd64",goos="linux",goversion="go1.20.4",revision="0b0467473916fd9e8526e2635c2a0b1c56011dff",tags="netgo",version="0.24.0"} 1
# HELP blackbox_exporter_config_last_reload_success_timestamp_seconds Timestamp of the last successful configuration reload.
# TYPE blackbox_exporter_config_last_reload_success_timestamp_seconds gauge
blackbox_exporter_config_last_reload_success_timestamp_seconds 1.7138572975539148e+09
# HELP blackbox_exporter_config_last_reload_successful Blackbox exporter config loaded successfully.
# TYPE blackbox_exporter_config_last_reload_successful gauge
blackbox_exporter_config_last_reload_successful 1
# HELP blackbox_module_unknown_total Count of unknown modules requested by probes
# TYPE blackbox_module_unknown_total counter
blackbox_module_unknown_total 0
# HELP go_gc_duration_seconds A summary of the pause duration of garbage collection cycles.
# TYPE go_gc_duration_seconds summary
go_gc_duration_seconds{quantile="0"} 1.3916e-05
go_gc_duration_seconds{quantile="0.25"} 1.9254e-05
go_gc_duration_seconds{quantile="0.5"} 2.8971e-05
go_gc_duration_seconds{quantile="0.75"} 4.531e-05
go_gc_duration_seconds{quantile="1"} 0.000139124
go_gc_duration_seconds_sum 0.447814159
go_gc_duration_seconds_count 13657
# HELP go_goroutines Number of goroutines that currently exist.
# TYPE go_goroutines gauge
go_goroutines 16
# HELP go_info Information about the Go environment.
# TYPE go_info gauge
go_info{version="go1.20.4"} 1
# HELP go_memstats_alloc_bytes Number of bytes allocated and still in use.
# TYPE go_memstats_alloc_bytes gauge
go_memstats_alloc_bytes 4.607336e+06
# HELP go_memstats_alloc_bytes_total Total number of bytes allocated, even if freed.
# TYPE go_memstats_alloc_bytes_total counter
go_memstats_alloc_bytes_total 3.6049210816e+10
# HELP go_memstats_buck_hash_sys_bytes Number of bytes used by the profiling bucket hash table.
# TYPE go_memstats_buck_hash_sys_bytes gauge
go_memstats_buck_hash_sys_bytes 1.626865e+06
# HELP go_memstats_frees_total Total number of frees.
# TYPE go_memstats_frees_total counter
go_memstats_frees_total 1.60783125e+08
# HELP go_memstats_gc_sys_bytes Number of bytes used for garbage collection system metadata.
# TYPE go_memstats_gc_sys_bytes gauge
go_memstats_gc_sys_bytes 8.258376e+06
# HELP go_memstats_heap_alloc_bytes Number of heap bytes allocated and still in use.
# TYPE go_memstats_heap_alloc_bytes gauge
go_memstats_heap_alloc_bytes 4.607336e+06
# HELP go_memstats_heap_idle_bytes Number of heap bytes waiting to be used.
# TYPE go_memstats_heap_idle_bytes gauge
go_memstats_heap_idle_bytes 5.586944e+06
# HELP go_memstats_heap_inuse_bytes Number of heap bytes that are in use.
# TYPE go_memstats_heap_inuse_bytes gauge
go_memstats_heap_inuse_bytes 6.209536e+06
# HELP go_memstats_heap_objects Number of allocated objects.
# TYPE go_memstats_heap_objects gauge
go_memstats_heap_objects 9562
# HELP go_memstats_heap_released_bytes Number of heap bytes released to OS.
# TYPE go_memstats_heap_released_bytes gauge
go_memstats_heap_released_bytes 4.685824e+06
# HELP go_memstats_heap_sys_bytes Number of heap bytes obtained from system.
# TYPE go_memstats_heap_sys_bytes gauge
go_memstats_heap_sys_bytes 1.179648e+07
# HELP go_memstats_last_gc_time_seconds Number of seconds since 1970 of last garbage collection.
# TYPE go_memstats_last_gc_time_seconds gauge
go_memstats_last_gc_time_seconds 1.7139477080350378e+09
# HELP go_memstats_lookups_total Total number of pointer lookups.
# TYPE go_memstats_lookups_total counter
go_memstats_lookups_total 0
# HELP go_memstats_mallocs_total Total number of mallocs.
# TYPE go_memstats_mallocs_total counter
go_memstats_mallocs_total 1.60792687e+08
# HELP go_memstats_mcache_inuse_bytes Number of bytes in use by mcache structures.
# TYPE go_memstats_mcache_inuse_bytes gauge
go_memstats_mcache_inuse_bytes 2400
# HELP go_memstats_mcache_sys_bytes Number of bytes used for mcache structures obtained from system.
# TYPE go_memstats_mcache_sys_bytes gauge
go_memstats_mcache_sys_bytes 15600
# HELP go_memstats_mspan_inuse_bytes Number of bytes in use by mspan structures.
# TYPE go_memstats_mspan_inuse_bytes gauge
go_memstats_mspan_inuse_bytes 77760
# HELP go_memstats_mspan_sys_bytes Number of bytes used for mspan structures obtained from system.
# TYPE go_memstats_mspan_sys_bytes gauge
go_memstats_mspan_sys_bytes 97920
# HELP go_memstats_next_gc_bytes Number of heap bytes when next garbage collection will take place.
# TYPE go_memstats_next_gc_bytes gauge
go_memstats_next_gc_bytes 6.394736e+06
# HELP go_memstats_other_sys_bytes Number of bytes used for other system allocations.
# TYPE go_memstats_other_sys_bytes gauge
go_memstats_other_sys_bytes 615263
# HELP go_memstats_stack_inuse_bytes Number of bytes in use by the stack allocator.
# TYPE go_memstats_stack_inuse_bytes gauge
go_memstats_stack_inuse_bytes 786432
# HELP go_memstats_stack_sys_bytes Number of bytes obtained from system for stack allocator.
# TYPE go_memstats_stack_sys_bytes gauge
go_memstats_stack_sys_bytes 786432
# HELP go_memstats_sys_bytes Number of bytes obtained from system.
# TYPE go_memstats_sys_bytes gauge
go_memstats_sys_bytes 2.3196936e+07
# HELP go_threads Number of OS threads created.
# TYPE go_threads gauge
go_threads 9
# HELP process_cpu_seconds_total Total user and system CPU time spent in seconds.
# TYPE process_cpu_seconds_total counter
process_cpu_seconds_total 111.25
# HELP process_max_fds Maximum number of open file descriptors.
# TYPE process_max_fds gauge
process_max_fds 524288
# HELP process_open_fds Number of open file descriptors.
# TYPE process_open_fds gauge
process_open_fds 14
# HELP process_resident_memory_bytes Resident memory size in bytes.
# TYPE process_resident_memory_bytes gauge
process_resident_memory_bytes 2.1430272e+07
# HELP process_start_time_seconds Start time of the process since unix epoch in seconds.
# TYPE process_start_time_seconds gauge
process_start_time_seconds 1.71385729658e+09
# HELP process_virtual_memory_bytes Virtual memory size in bytes.
# TYPE process_virtual_memory_bytes gauge
process_virtual_memory_bytes 7.43923712e+08
# HELP process_virtual_memory_max_bytes Maximum amount of virtual memory available in bytes.
# TYPE process_virtual_memory_max_bytes gauge
process_virtual_memory_max_bytes 1.8446744073709552e+19
# HELP promhttp_metric_handler_requests_in_flight Current number of scrapes being served.
# TYPE promhttp_metric_handler_requests_in_flight gauge
promhttp_metric_handler_requests_in_flight 1
# HELP promhttp_metric_handler_requests_total Total number of scrapes by HTTP status code.
# TYPE promhttp_metric_handler_requests_total counter
promhttp_metric_handler_requests_total{code="200"} 0
promhttp_metric_handler_requests_total{code="500"} 0
promhttp_metric_handler_requests_total{code="503"} 0
Well, I don’t see any probe_http_status_code metrics…
Can you try:
http://localhost:9115/probe?target=myweb.com&module=probe_http_status_code
# HELP probe_dns_lookup_time_seconds Returns the time taken for probe dns lookup in seconds
# TYPE probe_dns_lookup_time_seconds gauge
probe_dns_lookup_time_seconds 0.021402638
# HELP probe_duration_seconds Returns how long the probe took to complete in seconds
# TYPE probe_duration_seconds gauge
probe_duration_seconds 5.000813704
# HELP probe_failed_due_to_regex Indicates if probe failed due to regex
# TYPE probe_failed_due_to_regex gauge
probe_failed_due_to_regex 0
# HELP probe_http_content_length Length of http content response
# TYPE probe_http_content_length gauge
probe_http_content_length 492128
# HELP probe_http_duration_seconds Duration of http request by phase, summed over all redirects
# TYPE probe_http_duration_seconds gauge
probe_http_duration_seconds{phase="connect"} 0.010312636
probe_http_duration_seconds{phase="processing"} 4.915694718
probe_http_duration_seconds{phase="resolve"} 0.024412402
probe_http_duration_seconds{phase="tls"} 0.016234392
probe_http_duration_seconds{phase="transfer"} 0.023706651
# HELP probe_http_redirects The number of redirects
# TYPE probe_http_redirects gauge
probe_http_redirects 2
# HELP probe_http_ssl Indicates if SSL was used for the final redirect
# TYPE probe_http_ssl gauge
probe_http_ssl 1
# HELP probe_http_status_code Response HTTP status code
# TYPE probe_http_status_code gauge
probe_http_status_code 200
# HELP probe_http_uncompressed_body_length Length of uncompressed response body
# TYPE probe_http_uncompressed_body_length gauge
probe_http_uncompressed_body_length 52793
# HELP probe_http_version Returns the version of HTTP of the probe response
# TYPE probe_http_version gauge
probe_http_version 2
# HELP probe_ip_addr_hash Specifies the hash of IP address. It's useful to detect if the IP address changes.
# TYPE probe_ip_addr_hash gauge
probe_ip_addr_hash 1.712863942e+09
# HELP probe_ip_protocol Specifies whether probe ip protocol is IP4 or IP6
# TYPE probe_ip_protocol gauge
probe_ip_protocol 4
# HELP probe_ssl_earliest_cert_expiry Returns last SSL chain expiry in unixtime
# TYPE probe_ssl_earliest_cert_expiry gauge
probe_ssl_earliest_cert_expiry 1.731023999e+09
# HELP probe_ssl_last_chain_expiry_timestamp_seconds Returns last SSL chain expiry in timestamp
# TYPE probe_ssl_last_chain_expiry_timestamp_seconds gauge
probe_ssl_last_chain_expiry_timestamp_seconds 1.731023999e+09
# HELP probe_ssl_last_chain_info Contains SSL leaf certificate information
# TYPE probe_ssl_last_chain_info gauge
probe_ssl_last_chain_info{fingerprint_sha256="5c454649c612a1e6e2e3f2e6636a8a43a4c684ca61b44dd3f8a0029611fc562d",issuer="CN=Sectigo RSA Domain Validation Secure Server CA,O=Sectigo Limited,L=Salford,ST=Greater Manchester,C=GB",subject="CN=*.myweb.com",subjectalternative="*.myweb.com,myweb.com"} 1
# HELP probe_success Displays whether or not the probe was a success
# TYPE probe_success gauge
probe_success 0
# HELP probe_tls_version_info Returns the TLS version used or NaN when unknown
# TYPE probe_tls_version_info gauge
probe_tls_version_info{version="TLS 1.3"} 1
Since blackbox is able to retrieve the probe_http_status_code but can’t reach it via the /metric endpoint, the problem probably comes from the blackbox.yml configuration.
Maybe your blackbox is taking too long to retrieve the status_code? Try to increase your timeout in your probe_http_status_code. I don’t think this well solve any problem, but who knows?
You can also try to add a skip_verify in case there’s an SSL/TLS issue. I don’t think so since your blackbox fetch other metrics…
prober: http
timeout: 5s
http:
method: GET
tls_config:
If this don’t work, I’m sorry but I’ll not be able to help you further more
: your configuration file looks good for me…
I really appreciate your response, thank you very much for your time.
Yes, you are correct, now the probe_http_status_code appears. Look at the one I marked in red, the icon is different from the others.
But in Grafana, it hasn’t appeared yet. I have restarted the blackbox, Prometheus, and Grafana services, and I have also opened it in incognito mode in the browser.
So the issue was the timeout?
I’m unsure why the probe_http_status_code icon looks like that and its description says “Past Query,” while the others are gauges. Also, until now, probe_http_status_code hasn’t appeared in Grafana’s metrics browser.
To make it simple:
So it’s actually weird that your prometheus show it as a past query. Also, when checking via blackbox it was a gauge…
Can you reach http://localhost:9119/metrics again to check how it goes?
blackbox_exporter_config_last_reload_success_timestamp_seconds 1.7140337927072158e+09
go_gc_duration_seconds{quantile="0"} 1.2944e-05
go_gc_duration_seconds{quantile="0.25"} 1.8617e-05
go_gc_duration_seconds{quantile="0.5"} 2.8591e-05
go_gc_duration_seconds{quantile="0.75"} 4.1958e-05
go_gc_duration_seconds{quantile="1"} 0.000478121
go_gc_duration_seconds_sum 0.007460437
go_gc_duration_seconds_count 212
go_goroutines 15
go_memstats_alloc_bytes 5.16468e+06
go_memstats_alloc_bytes_total 5.4852052e+08
go_memstats_buck_hash_sys_bytes 1.490761e+06
go_memstats_frees_total 2.41399e+06
go_memstats_gc_sys_bytes 8.266496e+06
go_memstats_heap_alloc_bytes 5.16468e+06
go_memstats_heap_idle_bytes 5.12e+06
go_memstats_heap_inuse_bytes 6.643712e+06
go_memstats_heap_objects 11060
go_memstats_heap_released_bytes 4.481024e+06
go_memstats_heap_sys_bytes 1.1763712e+07
go_memstats_last_gc_time_seconds 1.7140351501326642e+09
go_memstats_mallocs_total 2.42505e+06
go_memstats_mspan_inuse_bytes 73920
go_memstats_next_gc_bytes 6.262816e+06
go_memstats_other_sys_bytes 513871
go_memstats_sys_bytes 2.2934792e+07
go_threads 8
process_cpu_seconds_total 1.67
process_open_fds 13
process_resident_memory_bytes 2.0914176e+07
process_start_time_seconds 1.71403379173e+09
process_virtual_memory_bytes 7.43661568e+08
/metrics endpoint doesn’t provide test results(e. g. status code). You have to scrape /probe endpoint with all required parameters.
hi @jangaraj
What should I do? Is there anything I need to change in the blackbox.yml?
I think this, http://localhost:9115/probe?target=myweb.com&module=probe_http_status_code, is what @jangaraj is talking about… But this doesn’t solve your past query issue.
Hey @codi639
you are right, I should not need to add probe_http_status_code inside prometheus.yml file
This issue has been solved, thank you very much
