How to Monitor Multiple URLs using Prometheus/Grafana
As we are new to this tool, Please help in this regard.
  • What Grafana version and what operating system are you using? RHEL 8 , Grafana 9.3.6 and Prometheus 2.42.0,Blacbox Exporter 0.43
  • What are you trying to achieve? - We have bunch of URLs/websites to be monitored in Table format in Grafana
  • How are you trying to achieve it? - We have configured Prometheus/Blackbox Exporter/Grafana
  • What happened? We have created Separate Folders for Each team and trying to list only the URLs specific to that team alone by setting the preferences, but the URL’s in prometheus.yml file is taken globally and showing up in other dashboard/Folders too.
  • What did you expect to happen? - We need to statically show the List of URL’s specific to each and every team that which are configured in the concerned folder
  • Can you copy/paste the configuration(s) that you are having problems with? We have used the file_sd_configs and using separate files for each team’s URLs
  • Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. - not seeing Error.
  • Did you follow any online instructions? If so, what is the URL? - No
Hi Team - Please can someone look into this and help us?
Please paste the prometheus scrape config of your blackbox job…
After analyzed this config, it will be easier to make proper scrape config.
Regards,
Fadjar340
Hi - Thanks for looking into this and below is the content what we have currently in prometheus.yml file
scrape_configs:
- job_name: “monitoring job”
metrics_path: /probe
params:
module: [http_2xx]
file_sd_configs:
- files:
- /home/targets/a_targets.yml
- /home/targets/b_targets.yml
- /home/targets/c_targets.yml
- /home/targets/d_targets.yml
relabel_configs:
- source_labels: [address]
target_label: __param_target
- source_labels: [__param_target]
target_label: instance
- target_label: address
replacement: hostname:9115 #BlackBox Exporter Instance
You can differentiate the job per target and build separate dashboard to each team.
Below the sample for 2 teams:
scrape_configs:
- job_name: “monitoring_job_team_a”
params:
module: [http_2xx]
file_sd_configs:
- files:
relabel_configs:
- source_labels: [**address** ]
- target_label: **address**
- job_name: “monitoring_job_team_b”
params:
module: [http_2xx]
file_sd_configs:
- files:
relabel_configs:
Then build team a dashboard with filter job=“monitoring_job_team_a”
So with other team, then each team have their own target to watch.
Regards,
Fadjar
Thank You, let me try this and post the outcome
We are unable to start the Prometheus with the given configuration in Place and below is the error we are facing
ts=2023-04-10T04:36:27.694Z caller=main.go:468 level=error msg=“Error loading config (–config.file=prometheus.yml)” file=//prometheus.yml err=“parsing YAML file prometheus.yml: yaml: line 32: did not find expected alphabetic or numeric character”
Tried with the below options:
relabel_configs:
relabel_configs:
- source_labels: [address ] ----> Space after two stars
relabel_configs:
- source_labels: [ address ] ---->Spaces begining and after
Note that the above snippet is missing the ** in the address
Is there any error that prometheus produced?
Yes, here it is and it didn’t come up at all
here the line 32 is the [** address ]
Find the line 32 and check the conformity in the Prometheus documentation. This is yaml file and it’s easy enough to modify. Or you can check using yaml online checker…
Modify as per your environment.
My sample just to show how to differentiate the job to make your dashboard easier to separate.
Regards,
Fadjar
ok thank you for the quick response, will update and let you know the outcome
Tried like the above option, but getting an error and the target status is UKNOWN
Error : Invalid : not a valid start token
Probably you need to remove all the “*” in the address, I saw that * make bold previous post…
Tried that too, seeing the below error
Check the log using tail -f then try to restart prometheus.
Please paste the log here…
Hi @fadjar340 - Thanks for your Help, not seeing the Error
