I’m running Grafana version 9.2.3 on Ubuntu 20, and I’m trying to monitor a website using the Prometheus Blackbox exporter and the probe_http_status_code module. The website seems to be working fine, and Prometheus is reporting that it’s up, but Grafana is showing that it’s down. I’ve uploaded my Blackbox configuration and Prometheus configuration.
I’m new to Grafana and could use some help troubleshooting this issue. Can you please provide guidance on how to identify and fix the problem? Thank you!
Website status:
Grafana:
- blackbox yml:
modules:
http_2xx:
prober: http
http:
ip_protocol_fallback: true
tcp:
icmp:
dns:
http_post_2xx:
prober: http
http:
method: POST
tcp:
icmp:
dns:
icmp:
prober: icmp
http:
tcp:
icmp:
dns:
irc_banner:
prober: tcp
http:
tcp:
query_response:
- send: NICK prober
- send: USER prober prober prober :prober
- expect: PING :([^ ]+)
send: PONG ${1}
- expect: ^:[^ ]+ 001
icmp:
dns:
pop3s_banner:
prober: tcp
http:
tcp:
query_response:
- expect: ^+OK
tls: true
icmp:
dns:
ssh_banner:
prober: tcp
http:
tcp:
query_response:
- expect: ^SSH-2.0-
icmp:
dns:
tcp_connect:
prober: tcp
http:
tcp:
icmp:
dns:
- prometheus yml
- job_name: blackbox
honor_timestamps: true
params:
module:
- http_2xx
scrape_interval: 15s
scrape_timeout: 10s
metrics_path: /probe
scheme: http
follow_redirects: true
relabel_configs:
- source_labels: [__address__]
separator: ;
regex: (.*)
target_label: __param_target
replacement: $1
action: replace
- source_labels: [__param_target]
separator: ;
regex: (.*)
target_label: instance
replacement: $1
action: replace
- separator: ;
regex: (.*)
target_label: __address__
replacement: localhost:9115
action: replace
static_configs:
- targets:
- https://prolificapp.in
- https://shreemarutinandan.com
- https://procliniq.in
- https://pro.ogaanlam.com
- https://fundbridge.in
- https://admin.fundbridge.in
- https://ops360.live
- https://live.shreemarutinandan.com
- https://fueasia.org
- https://martnmore.in
- https://walkinmart.in
- https://api.prolificapp.in
- https://api.fundbridge.in
- https://api.procliniq.in
- https://api.fueasia.org
- https://needs24.prolificapp.in
- https://api.ogaanlam.com
- https://77.martnmore.in/mm77
- https://93.martnmore.in
- https://120.martnmore.in
- https://122.martnmore.in
- https://live.urbngrocers.com
- http://needs93.prolificapp.in
- https://mail.proeffico.email
- https://vhstechnology.in
- https://thecuriousaders.com
- https://swachhbharatcaptains.in
- https://deepikafoi.in
