Plugin not found, no installed plugin with that id
Hi
I’ve just installed Grafana on Centos
# yum install grafana
POSTTRANS: Running script
Verifying : grafana-6.6.2-1.x86_64 1/1
Installed:
grafana.x86_64 0:6.6.2-1
Then I created a datasource.yaml file in /etc/grafana/provisioning/datasources
# # config file version
apiVersion: 1
# # list of datasources that should be deleted from the database
#deleteDatasources:
# - name: Graphite
# orgId: 1
datasources:
- name: InfluxDB
** type: InfluxDB**
** access: direct**
** orgId: 1**
** url: http://xx.xx.xx.xx:8086**
** password: ig_graf**
** user: ig_graf**
** database: telegraf**
** isDefault: true**
Then started Grafana
# service grafana-server start
All looks ok. no errors in logs
I log into Grafana and go to datasource tab. I can see my datasource has been added.
However when I click on it to view detail I get error:
So now I’m complexed as you why? Any hints appreciated
I think issue is that plugin which you want to use is not installed. Did you check plugin list in grafana. Second way to check plugins list is navigate to this folder " grafana-6.5.2\data\plugins " . If not installed just install that plugin.
Solved!
The yaml file field for type was wong:
Replaced:
type: InfluxDB
With
type: influxdb
e.g all lower case
All good now
Thanks! This pointed me in the right direction :slight_smile:
