Grafana v10.2.2 / Windows 10 -
Display only selected JSON fields in a Time Series Visualization -
Subscribing to an MQTT stream that is sending a JSON string.
The JSON string has the following format:
{ “seq”:1, “value1”:1,“value2”:2} -
What happened?
All the fields present in the data object are printed in the Time Series.
I get a graph line for seq, value1 and value2 when I would like only a few selected values to be plotted -
I would like, for instance, to only plot the value associated with the seq field -
I did try different solutions though I do not think they generated configurations I can share -
None that I can identify -
Google a few things including “Transform Data” and selecting “Extract Fields”, then JSON, adding a path to the field (“seq”) and selecting “Replace all fields”
Welcome @jsstoezel
You have a few options
- create a dashboard variable of
seqs and use that for filtering - use
Query filtertransformation
But is { "seq":1, "value1":1,"value2":2} really what the result looks like? Please post real structure of data minus confidential stuff
