Using Grafana Cloud version 9.3.6
- What are you trying to achieve?
Following a tutorial online for using the JSON API plugin to use JSON data as a grafana datasource, I hit this endpoint GET https://api.bls.gov/publicAPI/v1/timeseries/data/LNS14000000.
I would like to display unemployment data from a JSON datasource over time (months and years) but as you can see the way the endpoint serves the months field is in this string format: “M01” … “M12” at the JSON path $.Results.series[0].data[*].period. Here is an example of the data in table view to explain what i want to do:
As it stands at the moment, if I change the data type of the year field from String to Time then I can display this data as a time series but it only has data points every year, not every month.
I want to process the values in the period column, removing the leading “M” character from the string and append these to the year field with a hyphen so the end result would be something like this from the image above:
2022-09
2022-08
2022-07
etc. which I then assume I can cast to the Time data type to display data points at the level of months not just years.
- How are you trying to achieve it?
I tried using various of the Transform options documented here including Extract fields, rename by regex etc. but would not achieve the desired result.
- What happened?
Am not able to use any of these Transformations to process the period field and append the output to the year field to create a new Time of the format YYYY-MM. Is this sort of processing not possible inside Grafana using the Transform tab?
