I am using Grafana 9.5.3 -
I am querying “time” and one more column “processes” from a PSQL table. The query works fine. The “processes” field is essentially a JSON output. I need to plot a time series Graph with respect to the JSON output and time. The data in table format looks like below in Grafana:
In Transform tab, I am trying to Extract the values from JSON field from the processes column and keeping the time as well to plot the time series chart -
What happened?
As soon as i extract the JSON value the Chart goes blank and does not show anything and looks like it has crashed as below:
I expected it to plot a time series chart where with respect to time, the key should be seen as a Legend and the value as the point on the chart. The chart works fine in Grafana 10.0.3, BUT It is not working in 9.5.3. -
No UI logs found or any errors seen -
is your time field UTC?
I have set it to Auto. It picks up to CDT
