Hello
I am using Grafana Cloud with JSON API.
With JSON I query a service and get the following return values:
new, started, up, grace, down, and paused.
I want to do a mapping to display the values in a time series panel:
down = 0
up = 1
new = 2
ā¦
Is there a way to do something like this?
Hi there @anon89763442
best way for us to help you is to share your unformatted data from the inspect drawer, or a screenshot of your query results visualized using the table panel
you can convert values using value mappings, but without timestamps your data will not graph on the time series panel
Hi there @anon70503803
Thanks for your answer!
I tried the approach with value mappings. But as you say I am missing the timestamps to make a time series.
In the meantime I had contact with Grafana support. It turned out that it is not possible to implement the solution as I wanted.
Therefore I will choose another form of display.
Best
Dan
