Making a simple time series chart from a JSON log file. Complete newbie
    v9.2.1
    Trying to get a time series chart from JSON log information from a file using Loki data source
    I don’t know what I’m doing. Very new to grafana. I can find my host’s log file using label filters in the query. Beyond that I’m lost
  • What happened?
    Data is missing a number field
    The JSON data contains an id and date, plus some other numeric info I want to plot on the chart Y axis with time/date on the X axis. A new log with values gets pushed once per hour to grafana, and grafana is getting them (see explanation below).
    {hostname=“hostname”, filename=“data.log”} | json FIELD_I_WANT_TO_GRAB
    I don’t even know if I’m doing this right. That’s about as far as I got before brain fade.
    Not really, no. I can switch the data format to table, but the fields here are “labels”, “Time”, “line”, “tsNs”, and “id”. All my JSON data is visible inside the Line field, verbatim to what’s in
    each log entry in log file. (e.g. {“id”:“12345”, “date”: “2022-10-20 01:00:00”, “TOTAL”: 1, “OTHER_TOTAL”: 5} etc.
    I just want the table to have all my JSON info
    Nope. Just muddling my way through
