Is it possible to parse json files with Grafana Loki?
Hi Folks, I am trying to use Loki and Grafana to make a MySql qeury execution time visualization. I’m not able to properly configure Promtail to parse JSON logs. The log structure is a JSON list that has objects inside which looks smth like this:
    "THREAD_ID": 129265,
    "EVENT_ID": 2555,
    "END_EVENT_ID": 2577,
    "EVENT_NAME": "statement/sql/select",
    "SOURCE": "init_net_server_extension.cc:102",
    "TIMER_START": 674551125162346000,
    "TIMER_END": 674551125629310000,
    "TIMER_WAIT": 466964000,
    "LOCK_TIME": 0,
    "SQL_TEXT": "SELECT\n\t\t    TABLE_SCHEMA,\n\t\t    TABLE_NAME,\n\t\t
                            TABLE_TYPE,\n\t\t    ifnull(ENGINE, 'NONE') as ENGINE,\n\t\t    ifnull(VERS
                            ION, '0') as VERSION,\n\t\t    ifnull(ROW_FORMAT, 'NONE') as
                            ROW_FORMAT,\n\t\t    ifnull(TABLE_ROWS, '0') as TABLE_ROWS,\n\t\t
                            ifnull(DATA_LENGTH, '0') as DATA_LENGTH,\n\t\t    ifnull(INDEX_LENGTH,
                            '0') as INDEX_LENGTH,\n\t\t    ifnull(DATA_FREE, '0') as DATA_FREE,\n\t\t
                            ifnull(CREATE_OPTIONS, 'NONE') as CREATE_OPTIONS\n\t\t  FROM
                            information_schema.tables\n\t\t  WHERE TABLE_SCHEMA =
                            'test_file_service'",
    "DIGEST": "d878e3005775daaa0064fcc5f54e9669d246eabe67e37b5a6ae8fe8fc2a281f5",
    "DIGEST_TEXT": "SELECT `TABLE_SCHEMA` , TABLE_NAME , `TABLE_TYPE` , `ifnull` (
                                   ENGINE , ? ) AS ENGINE , `ifnull` ( `VERSION` , ? ) AS `VERSION` , `$
                                   fnull` ( ROW_FORMAT , ? ) AS ROW_FORMAT , `ifnull` ( `TABLE_ROWS`
                                   , ? ) AS `TABLE_ROWS` , `ifnull` ( `DATA_LENGTH` , ? ) AS
                                  `DATA_LENGTH` , `ifnull` ( `
                                   INDEX_LENGTH` , ? ) AS `INDEX_LENGTH` , `ifnull` ( `DATA_FREE` , ? )
                                   AS `DATA_FREE` , `ifnull` ( `CREATE_OPTIONS` , ? ) AS `
                                   CREATE_OPTIONS` FROM `information_schema` . `tables` WHERE
                                   `TABLE_SCHEMA` = ?",
    "CURRENT_SCHEMA": null,
    "OBJECT_TYPE": null,
    "OBJECT_SCHEMA": null,
    "OBJECT_NAME": null,
    "OBJECT_INSTANCE_BEGIN": null,
    "MYSQL_ERRNO": 0,
    "RETURNED_SQLSTATE": null,
    "MESSAGE_TEXT": null,
    "EXECUTION_ENGINE": "PRIMARY",
    "start_time": "2023-11-01 17:36:52.125163",
    "timer_wait_ms": "0.466964",
    "timer_wait_s": "0.000467",
    "lock_time_s": "0",
    "wait_human": "466.96 us",
    "timestamp_rnd": "1698860212",
    "timestamp": "1698860212.125163"
I have all the logs files stored on a VM which hosts Grafana, loki, and Promtail as docker-containers in a docker-compose file, this is my promtail-local-config.yaml configurations, which i’m struggling to figure out:
 server:
  http_listen_port: 9080
  grpc_listen_port: 0
positions:
  filename: /tmp/positions.yaml
clients:
  - url: http://loki:3100/loki/api/v1/push
scrape_configs:
  - job_name: system
    pipeline_stages:
      - json:
          expressions:
            timer_wait_s: timer_wait_s
            timer_wait_ms: timer_wait_ms
            wait_human: wait_human
            timestamp: timestamp
      - timestamp:
          source: time
          format: RFC3339Nano
    static_configs:
      - targets:
          - localhost
        labels:
          job: varlogs
          __path__: /var/log/slow_log_query/*.log
This is my docker-compose file:
version: "3"
networks:
  prom:
services:
  loki:
    image: grafana/loki:2.9.0
    ports:
      - "3100:3100"
    command: -config.file=/etc/loki/local-config.yaml
    networks:
      - prom
  promtail:
    image: grafana/promtail:2.9.0
    volumes:
      - /var/log/slow_log_query:/var/log/slow_log_query
      - ./promtail-local-config.yaml:/etc/promtail/config.yml:ro
    command: -config.file=/etc/promtail/config.yml
    networks:
      - prom
  grafana:
    environment:
      - GF_PATHS_PROVISIONING=/etc/grafana/provisioning
      - GF_AUTH_ANONYMOUS_ENABLED=true
      - GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
    entrypoint:
      - sh
      - -euc
        mkdir -p /etc/grafana/provisioning/datasources
        cat <<EOF > /etc/grafana/provisioning/datasources/ds.yaml
        apiVersion: 1
        datasources:
        - name: Loki
          type: loki
          access: proxy
          orgId: 1
          basicAuth: false
          isDefault: true
          version: 1
          editable: false
        EOF
        /run.sh
    image: grafana/grafana:latest
    ports:
      - "3000:3000"
    networks:
      - prom
the containers are working just fine with the configured volumes and ports and everything. But when I access the explore page on Grafana and choose Loki as the data source I can’t find any labels or anything to interact with.
Any idea how to deal with such json logs ?
  1. Make sure all your components are working. Send a test log to Loki with API call, make sure it shows up in Grafana.
  2. You only need to parse JSON for labels that you care about. In your example, perhaps the only thing you really need is timestamp. And in the timestamp block you want to make sure the source matches a label from your json filter, and the format matches the actual format. So it would be something like this (not tested):
    pipeline_stages:
      - json:
          expressions:
            timestamp:
      - timestamp:
          source: timestamp
          format: Unix
