I’m currently facing difficulties configuring Promtail to parse JSON logs in Loki successfully. The log structure consists of a plain JSON string without any nesting
{ LEVEL: INFO,Class: net.provisioning.controller.BarringController,Thread: http-nio-9720-exec-4,IP: bs591/127.0.1.1,host: bs591,message: POST /barring/barrings-with-level,requestParam: actionType=ddd&channel=sss&reseller=ss&salesman=ss,requestBody: {“subscriptionId”:0,“channel”:“string”,“barringType”:“string”,“reseller”:“string”,“salesman”:“string”,“barringLevel”:“strinbffgfgfgfgg”},requestHeader: {“sec-fetch-mode”:“cors”,“content-length”:“161”,“referer”:“http://localhost:9720/swagger-ui/“,“sec-fetch-site”:“same-origin”,“accept-language”:“en-US,en;q=0.9”,“cookie”:“Idea-d9de4e9c=d62c8f22-b776-45ab-8abc-54bac78194b7”,“origin”:“http://localhost:9720”,“accept”:“application/vnd.-v1.0+json”,“sec-ch-ua”:”\“Not.A/Brand\”;v=\“8\”, "Chromium";v="114", "Google Chrome";v="114"”,“sec-ch-ua-mobile”:“?0”,“sec-ch-ua-platform”:“"Linux"”,“host”:“localhost:9720”,“connection”:“keep-alive”,“content-type”:“application/json”,“accept-encoding”:“gzip, deflate, br”,“user-agent”:“Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36”,“sec-fetch-dest”:“empty”},responseHeader: ,responseBody: invalid request properties,responseStatus: 400 BAD_REQUEST,requestId: null }"
I used following promtail config:
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: http://localhost:6350/loki/api/v1/push
scrape_configs: job_name: app-provisioning
static_configs:targets:- localhost
labels:
job: test-app-provisioning
app: test-app
host: test-apihub-prod-app
path: /home/apihub/log/app.provisioning.202311151.json
pipeline_stages: - cri: {}
match:
selector: ‘{job=“test-app-provisioning”}’
stages:
- json:
expressions:
level: “LEVEL”
class: “Class”
thread: “Thread”
ip: “IP”
host: “host”
message: “message”
requestParam: “requestParam”
requestBody: “requestBody”
requestHeader: “requestHeader”
responseHeader: “responseHeader”
responseBody: “responseBody”
responseStatus: “responseStatus”
requestId: “requestId”
source: “message”
drop_malformed: false
- labels:
level: “{{ .level }}”
class: “{{ .class }}”
thread: “{{ .thread }}”
ip: “{{ .ip }}”
host: “{{ .host }}”
message: “{{ .message }}”
requestParam: “{{ .requestParam }}”
requestBody: “{{ .requestBody }}”
requestHeader: “{{ .requestHeader }}”
responseHeader: “{{ .responseHeader }}”
responseBody: “{{ .responseBody }}”
responseStatus: “{{ .responseStatus }}”
requestId: “{{ .requestId }}”
I expected that by specifying the JSON parsing and labels, I would be able to view these labels in Grafana Explore. While I can see the log entries in Grafana, as depicted below, the issue is that I’m not seeing any labels that correspond to the JSON keys
- localhost
Any guidance on how to make this configuration work would be greatly appreciated. Thanks for any assistance!
