How to parse nested json in Promtail
I am having the following log which is in nested JSON
{"level":30,"time":1627625600625,"pid":15676,"hostname":"admin-hp-elitebook-840-g2","reqId":"req-2","req":{"method":"POST","url":"/v1/login","hostname":"127.0.0.1:3000","remoteAddress":"127.0.0.1","remotePort":55884},"msg":"incoming request"}
From that, i would like to create labels for method, URL, host i have tried the JSON expression like below in promtail
scrape_configs:
- job_name: plainlog
  pipeline_stages:
  - json:
      expressions:
        req: req
  - labels:
      req:
  - output:
      source: req
  static_configs:
  - targets:
      - localhost
    labels:
      job: plainlog
      __path__: /home/nidhin/Desktop/plainlog/*log
But it creates the label req and stores the JSON as value for the key req.Does anyone knows how to create labels from nested JSON
Hi @nidhinkumar06 did you find a solution ? same problem for me … no solution to parse a nested JSON. Some one from grafana could provide a POC please ?
I have not tried this but documentation shows an example here.
Be aware that Best practices advice against dynamic labels.
