Json logs processing in Promtail
Hello, I’m trying to configure Promtail and Loki with Caddyserver. It outputs json logfiles with multiple levels. Something like:
	"level": "info",
	"ts": 1613986597.8528846,
	"logger": "http.log.access.log1",
	"msg": "handled request",
	"request": {
		"remote_addr": "xxx.xxx.xxx.xxx:54754",
		"proto": "HTTP/2.0",
		"method": "GET",
		"host": "dash.xxxxxxx.com",
		"uri": "/grafana/api/datasources/pro...",
		"headers": {
		"tls": {
	"common_log": "xxx.xxx.xxx.xxx- - [22/Feb/2021:09:36:37 +0000] \"GET /grafana/api/datasou...",
	"duration": 0.24274698,
	"size": 625,
	"status": 200,
	"resp_headers": {
My job configuration is
  - job_name: caddy
    pipeline_stages:
    - json:
        expressions:
          level: level
          ts: ts
          logger: logger
          request:
    - json:
        expressions:
          remote_addr:
        source: request
    static_configs:
    - targets:
      - localhost
      labels:
        job: caddy
        host: dash.tinygs.com
        __path__: /var/log/caddy/*log
Grafana shows parsed json data but only up to first level, even if I do not use pipeline_stages section.
My intention is to parse request fields to use them as tags. Do you see any mistake in job definition?
Thanks
I’ve found that -output pipeline is mandatory to produce an output (makes sense). I will keep investigating that.
Hello @gmag11 ,
Did you find a solution ?
Thanks
