Grafana v10.3.3 on Ubuntu 22 LTS -
Transform data in a way that I can visualize it in a time series panel. -
Because of the way I receive the data I have to use data transformation. I’m just not able to achieve it the way I need it.
This is the Data I got:
"date": "2022-06-29T13:23:36+0200",
"value": "28.7"
"date": "2022-07-13T10:48:30+0200",
"value": "28.7"
"date": "2022-08-23T15:11:20+0200",
"value": "28.6"
"date": "2022-09-30T11:02:49+0200",
"value": "28.7"
"date": "2022-10-11T21:52:28+0200",
"value": "28.7"
"date": "2022-11-11T16:13:27+0100",
"value": "25.9"
"date": "2022-12-23T08:52:53+0100",
"value": "25.8"
"date": "2023-01-20T15:49:31+0100",
"value": "25.8"
"date": "2023-02-24T09:37:07+0100",
"value": "25.6"
"date": "2023-03-24T07:21:24+0100",
"value": "25.9"
"date": "2023-04-12T11:51:53+0200",
"value": "24.0"
"date": "2023-04-24T15:43:37+0200",
"value": "23.6"
"date": "2023-05-25T12:22:33+0200",
"value": "23.4"
"date": "2023-06-23T16:17:56+0200",
"value": "23.4"
"date": "2023-07-06T12:04:13+0200",
"value": "16.2"
"date": "2023-08-24T11:00:06+0200",
"value": "15.6"
"date": "2023-09-28T08:28:38+0200",
"value": "15.6"
"date": "2023-10-26T11:13:35+0200",
"value": "9.3"
"date": "2023-11-23T14:28:04+0100",
"value": "9.3"
"date": "2023-11-29T10:32:38+0100",
"value": "9.3"
"date": "2023-12-21T14:27:03+0100",
"value": "9.3"
"date": "2024-01-26T08:38:02+0100",
"value": "9.3"
"date": "2024-02-22T16:43:14+0100",
"value": "9.2"
"date": "2024-02-28T13:28:29+0100",
"value": "9.2"
"date": "2024-03-07T15:40:13+0100",
"value": "9.2"
Everything is in one column inside a table for now.
Which data transformations do I have to use to use the time series panel in order to see the values changing over time?
