Grafana v9.2.2 Windows 11 -
A time series visualization out from a JSON payload retrieved using HTTP request with Infinity data source. -
What happened?
A single point appears instead of plotting the series. -
To have plot a series. -
The data comes in the following shape:
"metricId":352528,
"metricName":"aaa",
"metricPath":"aaa",
"frequency":"SIXTY_MIN",
"metricValues":[
"startTimeInMillis":1702044000000,
"occurrences":1,
"current":2730,
"min":0,
"max":9613,
"useRange":true,
"count":64905,
"sum":5836044,
"value":90,
"standardDeviation":0
"startTimeInMillis":1702049000000,
"occurrences":1,
"current":2740,
"min":0,
"max":9617,
"useRange":true,
"count":64935,
"sum":5836074,
"value":80,
