avgdev
1
Grafana v11.0.1 (302831c125) OSS
I am trying trying to create a line graph with the Infinity datasource
I have an API that returns the following JSON
"timeseries": [
"label": "A",
"time": "2024-04-01",
"value": 270
"label": "B",
"value": 446
"label": "A",
"time": "2024-04-02",
"value": 382
"label": "B",
"value": 146
What happened?
Its not splitting the data into two lines
I expected the visualization to show two lines
Type: JSON
Parser: Default
Source: URL
Format: Table
I would appreciate any help
One of possible solutions is to use two Grafana transformations:
1 - Grouping to Matrix
2 - Convert field type
Result:
avgdev
3
Thank you very much for taking the time to look at my issue and provide me a solution. I appreciate it.
Is there any way I can structure the JSON reponse so that I dont have to use transformations? Thank you again.
Try something like this:
"timeseries": [
"time": "2024-04-01T00:00:00Z",
"A": "270.000000",
"B": "446.000000"
"time": "2024-04-02T00:00:00Z",
"A": "382.000000",
"B": "146.000000"
avgdev
5
That is awesome and exactly what I wanted. Thank you again very much for the quick and concise solution.
you dont need to restructure it nor use transformations
are you using uql by any chance to parse the json?
something like
I am using Inline source because I will be using the sample json you posted. Type: UQL, Format: Time Series
parse-json
| scope "timeseries"
| pivot sum("value"), "time", "label"
avgdev
7
Thank you for this. I will try it.
