Hi everyone.
I have some issues to create that type of multiple Time Series:
My JSON datas come from an API linked with Infinity and i format them in columns this way. For each column Unix in [0], Value in [1]:
To do that i configured the plugin to parse in FrontEnd, with columnar format, and i have selected the right columns.
After that, i extract the datas and convert them into Time and Number Value:
And i have this result, the values are mixed even if the Unix isn’t the same:
I have tried many things, changing Json format to use dict for each object instead of arrays, other transformations like ‘Prepare Time Series’, but the only solution i found is to make multiple Queries, one for each Curve. But for my application, i need to make a single Query.
Do you have a solution ?
Thank you
hello @gerryjouaud
please provide a sample json data?
For sure, here it is :
"panel1": {
"current shift": [
1745884821000,
0
1745885172000,
0
1745885172000,
1
"shift - 1": [
1745884821000,
0
1745884824000,
0
1745884824000,
1
1745884824000,
2
1745884824000,
3
1745885619000,
4
1745885619000,
5
"shift - 2": [
1745884821000,
0
1745885029000,
0
1745885029000,
1
1745885029000,
2
1745885029000,
3
1745885072000,
4
1745885072000,
5
Thank you for helping !
Edit:
And it doesn’t work when i try to access columns with something like that: ‘current shift.*.0’ to specify to grafana current shift time field for example.
I think the error come from the multiple extract fields, but do i have another solution ?
I realized with that little sample that the number of rows is determined by the first column ‘current shift’ here. So even others columns have 3 rows even if they have more row objects.
Must i format my Json in a different way and have for each object : [‘unix’,value1,value2,value3’] ?
Format JSON this way make the panel creation much easier, with only one understandable time stamp value for Grafana: [time_stamp,value1,value2,value3]
But just for my Grafana knowledge; was it possible with my previous format ?
You may need some JSONata massaging.
Example
$sort($map($keys($.panel1), function($key) {
return {
$key : $map($lookup($$.panel1, $key), function($v){
return {
"key": $key,
"timestamp": $v[0],
"value": $v[1]
}).*, function($l,$r){
$l.timestamp > $r.timestamp
