Pie Chart Plugin not available
Running grafana as a docker swarm service with the folloeing image grafana/grafana-oss:10.3.1
I am trying to import a dashboard. This dashboard depends on a plugin grafana-piechart-panel
Importing the dashboard via the ID
  • What happened?
A few panels are giving errors such as Panel plugin not found: grafana-piechart-panel
I can see from my plugin management page and the GitHub repo of this plugin that it comes pre-installed as a core plugin in Grafana.
  • Did you receive any errors in the Grafana UI or related logs? If so, please tell us exactly what they were.
Did you try:
@codi639
I did try this answer, but this was based on a non-docker solution, anyways I was able to fix it by going through the docker container setup in Grafana docs and adding the following section in my docker swarm config.
environment:
      GF_INSTALL_PLUGINS: grafana-piechart-panel
