Hello All,
I am attempting to install the piechart plugin on my Grafana v2.5 environment and no matter what I do the panel does now show as an option in the UI. I cloned the repository to /var/lib/grafana/plugins as documented and restarted the grafana-server service and that did not work. I also tried putting the plugin in a separate directory and referencing it as:
[plugin.piechart]
path = /home/usr/share/grafana/panel-plugin-piechart
I made sure that the grafana service has ownership of the plugin directory, and checked the grafana logs but it did not have useful information.https://github.com/grafana/panel-plugin-piechart | Hadoop
Thanks
