Panels' query has changed much on grafana8.1?
I just install grafana8.1, and I find its query is very different from before;
I used to query on grafana as below before:
but now I can’t find this format, so grafana8.1 delete this style query?
Hi @south_wind
What are you seeing instead? Here is a screenshot of the Influx query editor on Grafana 8.1.2:
I am farmiliar with wath your screenshot shows, but mine is as below:
maybe something is set wrong?
Ah, so you’ve configured your InfluxDB datasource to use Flux and not the legacy QL. Did you mean to do that?
yes, but I install influxdb2.0, so I only can select Flux,yes/?
