Orchestra City Maps Pluging Popup misplacement
I’m using the Orchestra City Maps plugin since I had some issues with the standard map-visualization.
Now there is small issue with Orchestra plugin, too.
One can configure a popup that shows query values when you hover over a marker on the map.
Some times that work quite well:
But in other situations the popup is shown far away from the marker, often even outside the visible part of the browser window. In this example I moved the map with the orange circle marker above the map with the blue triangle marker, without touching the map with the blue marker in any way. But now the popup is placed in a way that prevents it from being visible.
Is this a bug or can the position of the popup be configured in any way?
Best to ask this question on the github repo for this plugin
Did that already :wink:.
But looking at the other listed issues I’m not so sure, if they still maintain it. :thinking:
Yeah, I don’t think they keep up with that plugin much.
Next option, business text plugin with leaflet
Keep looking for the one that will do it all for you
Ok, I will wait for them to come back on Github. In case there is no response I will look further …
Thank you so far!
