Data display using Orchestra Cities map plugin
I’m trying to display data using Orchestra Cities. Currently, the data only appears when mouse over it.
Is there a way to make it always appear?
Yes, you can change the data display settings in Orchestra Cities so that it is always shown, not just when you hover over your mouse. You need to find the appropriate setting or option in the settings of the graph or widget you are using to display data and change its settings to “always display”. This can usually be done through the settings menu or control panel in the Orchestra Cities app.
