Orchestracities map panel GeoJSON
Hello
I want to create a layer on my map displaying static GeoJSON data from a file within the gazetteer folder. I know you can do this in the standard geomap panel but has anyone done it with the orchestracities map panel plugin?
Do you know if its possible to use css styling on the geojson shapes?
what are you attempting to do. and since this thread is closed might want to open a new one?
I created a new thread :slight_smile:
