Hello everyone,
I am using Grafana 10.2.3 Orchestra Cities Map and it drives me crazy. Because i dont get the position shown on the map.
this is my insert
data = "loco,uic=111111111ups_load_voltage="+str(load_voltage)+",ups_current="+str(current)+",ups_power="+str(power)+",ups_percent="+str(percent)+",ups_hs="+str(hs)
and the data of the insert look like that
car,uic=11111111 gps_hdop=0.8,gps_height=458.1,gps_latitude=40.4665013,gps_longitude=13.513669566666668,gps_quality=1i,gps_satellites=6i,gps_speed=0
so this all works for me.
my request in grafana looks like this
from(bucket: "bucket")
|> filter(fn: (r) => r["_measurement"] == "loco")
|> filter(fn: (r) => r["uic"] == "11111111 ")
|> filter(fn: (r) => r["_field"] == "gps_latitude" or r["_field"] == "gps_longitude" or r["_field"] == "gps_speed")
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: "mean")
And again everything is fine i am getting the data like i wrote upstairs
So this is the config i did in the plugin everything fine as well i think
The only thing what I cant explain and what makes me suspicious is that i can choose 3 times the
So on this problem now for 3 days. Any ideas?
