Operations in variable
I’d like to apply some basic string operations on variables.
I have a Custom variable with values id123 : Label123,id24 : Label234
In the panel title I’d like to choose the value of this key : value variable format and leave the key for the query.
However I can’t find any docs about it
check this out
it should be
key1 : value,key2 : value
seems like you might have it swapped? and spacing is sensitive
I have the same as you but the label preview does not show the same
What version of grafana?
I also tried as @yosiasz showed and use it like this
id1 : L1 , id2 : L2
Preview of values result is:
id1
id2
I am using Grafan ver 9 so will be good to know the version you are using.
