Variable query options: text + value in SQL
    9.2.5
I want to have nice-looking variables - with country names in this example.
In the SQL query, I’d like to use the respective country_id to optimize the SQL query.
    I have created an SQL query returning one column (<country_id>-<name>) and used the Regex option to split it into two pars: /(?<value>\d+)-(?<text>.*)/:
SELECT country_id || '-' || name FROM country
  • What happened?
It was a little complex to build the regex, but it worked.
I hoped that I could have something like the following, which is NOT working (it returns values from both columns, such as 1, 2, Germany, …):
SELECT country_id AS value, name AS text FROM country
no errors (when SQL was correct ;-))
I’m wondering, if there is a way around using the regex, if I provide the correct column names.
Thanks a lot!
Steffen
Doc is your good friend: PostgreSQL data source | Grafana documentation
Example:
SELECT hostname AS __text, id AS __value FROM host
Oops… that was a very clear RTFM case :upside_down_face: I skipped over that part somehow.
Sorry, I’m wondering how to mark the topic as solved :frowning:
