I am using mysql. The task is as follows. I have a “country name” variable. In mysql code, I want to insert not the name of the country, but the code.
SELECT concat(name, " ", code) FROM BillingCountry
But … there is a feature. When I select a variable, I want to see the name of the country (or a name-code pair), and only the country code is substituted in mysql
I got answer bymyself
link to doc of Grafana
Another option is a query that can create a key/value variable. The query should return two columns that are named __text and __value . The __text column value should be unique (if it is not unique then the first value is used). The options in the dropdown will have a text and value that allows you to have a friendly name as text and an id as the value. An example query with hostname as the text and id as the value:
SELECT hostname AS __text, id AS __value FROM my_host
at my case I use
SELECT name AS __text, code AS __value FROM billingCountry
but at sql script I use the BillingCountry.code
IF ('ALL' in ($countryOfUser), TRUE, BillingCountry.code in ($countryOfUser))
Can you share 3 to 4 rows of your data set and the query which you used and results for this query . I have a similar problem.
well, I have table BillingCountry and Users
at Grafana I create Grafana’s variable $countryOfUser which have list of countries by name of countries and code of countries.
In order to get a list of mapped values, I use a query with 2 entities:
you can see at screenshoot
And then dashboard users can use the filter on a graph or table where they see the names of countries.
And in sql query, I use country codes, since they are indexed for me
and I use code for got only from needed countries using by index of countries
SELECT
UNIX_TIMESTAMP(MAKEDATE(YEAR(registered), DAYOFYEAR(registered))) as time_sec,
COUNT(User.id) as value,
CONCAT("New Registrations ", IF ( $countryOfUser ='ALL', '', $countryOfUser)) as metric
FROM User
LEFT JOIN Country On Country.code = User.countryCode
WHERE $__timeFilter(User.registered) AND IF('ALL' in ($countryOfUser), TRUE, (Country.code in ($countryOfUser)))
GROUP BY DATE_FORMAT(registered,"%Y-%m-%d")
As a result, I got a quick query, since I use indexed fields
is it enough? Or you need some more details?
