Hey
I got a straightforward Grafana dashboard that uses the Node Graph panel and Prometheus metrics. But I’m facing several issues:
- The metric units of edges are not shown (for main and secondary stats)
- When I add a metric that should represent the nodes, nothing is shown within the nodes.
The metrics are:
twampy_latency_avg_edge{container=“sender”, endpoint=“metrics”, id=“twampy-dev-sender-2l8lf-twampy-dev-responder.twampy.svc.cluster.local”, instance=“10.0.0.23:8000”, job=“twampy/twampy-dev-sender”, mainstat=“11.24”, namespace=“twampy”, pod=“twampy-dev-sender-2l8lf”, source=“twampy-dev-sender-2l8lf”, target=“twampy-dev-responder.twampy.svc.cluster.local”}
twampy_result_node{container=“sender”, endpoint=“metrics”, id=“twampy-dev-sender-2l8lf”, instance=“10.0.0.23:8000”, job=“twampy/twampy-dev-sender”, mainstat=“ok”, namespace=“twampy”, pod=“twampy-dev-sender-2l8lf”, title=“twampy-dev-sender-2l8lf”}
Are these all known issues?
