Getting Metrics in Linux Node But Nothing In NGINX
    I’m using Grafana Cloud and Installed agent on AWS EC2 Instance Ubuntu 20.04.4 LTS server
    This is first time I’m using Grafana cloud, my intention is just to try out and see how well it works.
    I created a new account and got Pro subscription for now. I followed the NGINX & Linux Node agent installation tutorial.
    Test Integration is working fine.
  • What happened?
    I’m not getting proper metrics in the NGINX dashboard, also some of the Linux Node dashboards panel not working also some of them are giving wrong readings.
    Nginx:
    Dashboard 1:
    Dashboard 2:
    I expect the metrics to come properly.
ubuntu@ip-172-31-13-173:~$ sudo cat /etc/grafana-agent.yaml
integrations:
  node_exporter:
    enabled: true
    relabel_configs:
    - replacement: hostname
      target_label: instance
  prometheus_remote_write:
  - basic_auth:
      password: eyJrIjoiZDUwODQwODkzOTAyOGM3NTM5Y2YxNDhkNjE0YTIwNDUxMzFiOGQ4YSIsIm4iOiJzdGFjay00MDk3ODMtZWFzeXN0YXJ0LXByb20tcHVibGlzaGVyIiwiaWQiOjY4NzM2MH0=
      username: 520302
    url: https://prometheus-prod-10-prod-us-central-0.grafana.net/api/prom/push
logs:
  configs:
  - clients:
    - basic_auth:
        username: 259121
      url: https://logs-prod3.grafana.net/loki/api/v1/push
    positions:
      filename: /tmp/positions.yaml
    scrape_configs:
    - job_name: integrations/nginx
      static_configs:
      - labels:
          __path__: <path to json nginx access log>
          host: <http_hostname>
        targets:
        - localhost
    - job_name: integrations/node_exporter_journal_scrape
      journal:
        labels:
          instance: hostname
          job: integrations/node_exporter
        max_age: 24h
      relabel_configs:
      - source_labels:
        - __journal__systemd_unit
        target_label: unit
      - source_labels:
        - __journal__boot_id
        target_label: boot_id
      - source_labels:
        - __journal__transport
        target_label: transport
      - source_labels:
        - __journal_priority_keyword
        target_label: level
    target_config:
      sync_period: 10s
metrics:
  configs:
  - name: integrations
    remote_write:
    - basic_auth:
        username: 520302
  global:
    scrape_interval: 60s
    No, No errors so far.
    No.
Linux Node Dashboards SS:
Linux Node:
Dashboard 1:
Dashboard 2:
