Greetings, I’m still learning grafana, but i can’t figure this out.
I created several dashboards, all of them with influx queries, but there are so much repeated code(I did it because the deadline was near, and now I have some time to improve it). So I thought about creating a main dashboard to have the data to be shared among the rest of them.
But when I select the Mixed query type and the ‘Dashboard’ as the query ‘B’, I can get this message “Data source plugin does not export any Query Editor component”.
If you are using all Influx queries, are they from the same Influx DB? Acc. to the documentation, Mixed should be selected only when you have multiple (different) datasources.
Mixed - Select this to query multiple data sources in the same panel. When this data source is selected, Grafana allows you to select a data source for every new query that you add.
The first query will use the data source that was selected before you selected Mixed .
You cannot change an existing query to use the Mixed Data Source.
