8.3.3
Windows 10 -
Creating a Table panel that has 2 SQL Queries I want to merge, and using different Datasources on each - Datasources are Variables. -
I created the Variables, and I can see them in the top/main Datasource selection for the panel. So I select “Mixed”. Then I go to each Query and try to select the desired Variable. -
What happened?
None of the DS Variables are showing when trying to select on Query. -
To see the Variables and select them. -
This is where I select “Mixed” and can see the variables:
And this is when trying to select them on Query after selecting Mixed - Variables should be on top of list, but I checked the whole list and none are there:
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No errors.
I may be missing something, but can’t find what that is yet.
Let me know if you need more info.
