Enterprise (Free & unlicensed) | v9.0.3 (023f9251a) | Linux
- What are you trying to achieve?
I would like to use dashboard as an input to -- Mixed -- selector.
- How are you trying to achieve it?
I tried switching to a Mixed data source
- What happened?
I am met with an error message indicating that the dashboard plugin does not export a Query Editor component
I wanted to be able to merge data from multiple dashboards.
Is this behavior possible without creating or modifying a plugin?
If so, would it be better to modify the existing plugin for dashboards or to start from scratch?
