Navigation Issue in Grafana latest version
I updated the Grafana version to 6.6.0 and the navigation between dashboards seems to be not working properly, that is, while going from one dashboard to next one, the variable drop down selection seems to be reset to default.
Can anyone help in resolving this issue.
One possible way is to try this issue on older version if its happening on new one just open an issue. @anon34853223
@malamgir Thanks for the response.
I have checked with older versions of Grafana and the navigation works fine. The issue occurs in Grafana version 6.6.x. Also observed that this issue is randomly reproducible and not always.
Close this issue and marked solution.
Is it one of these issues you are observing on your instance?
Yes. This is the same issue we are facing
