Problems after upgrading to 7 - dashboard links no longer work
I have run an upgrade (well yum upgrade and restart) from 6.7 to 7, few issues:
  • the dashboard links to other dashboards seem gone (on any dashboard I’ve used it), - seeing this instead: image - they still have URL, but without the dashboard link,
one particular dashboard has extra issues on its own:
  • the table panel with 3 queries stopped working (= stopped showing data after an upgrade)
  • when going to time range zoom out on this particular dashboard, I get An unexpected error happened
    Details
    TypeError: Cannot read property ‘indexOf’ of undefined
    in t
    in t
    in div
    in div
    (continues)
Perhaps I missed something during an upgrade ? Thanks.
An update to my own post - when I add the link as external instead of dashboard it works, ie there seem to be a workaround. “Just” need to delete/re-add the links.
Same problem here. Some already existing dashboard links are still functioning, while others have disappeared. And I cannot create any new dashboard links successfully.
+1 Same here. Can’t create new Dashboard links. Some old links working, some not. Seems to be related to tags. I can create a dropdown link with no tags and I get the full list of dashboards. Adding any tag breaks the dropdown link.
The same happend to me. As a workaround I recreated links with the new dropdown flag.
It seems that is fixed in 7.0.1 by Dashboard/Links: Fixes open in new window for dashboard link ( https://github.com/grafana/grafana/pull/24772 )
