I’m using grafana 6.0.5. Created some panels in the dashboard and put some queries to each of the panels of the dashboard. Saved the dashboard.
But on refresh of the dashaboard, the queries in one panel are moving to the other panel in the display. If i edit a particular panel, i’m able to see the correct queries only. Why the display in panels getting changed on each refresh… This is pretty bad…
can you upgrade to the latest grafana version? a lot of improvements on this have been made.
Oops…I’m using grafana 7.2.1 not 6.0.5
$ /var/opt/icetools/grafana/grafana-7.2.1/bin/grafana-cli -v
Grafana CLI version 7.2.1
ok but you did not mention if your upgrade had helped?
No upgrade. I was saying i was using the 7.2.1 version of grafana since beginning.
And the issue exists with 7.2.1 only. Do you want me to check with more latest version?
yes
[quote=“gangaambati, post:5, topic:43388”]
[/quote
yes
Even with the 7.4.2, seeing the same issue. no luck.
and if you downgrade to version 6, is it better then?
