Grafana version v11.6 and v12.0.1 on InfluxDB v1.8 Ubuntu -
I want to use multiple panels as a data source for another panel. This works correctly. -
Using the panels as a data source and using transformations to do data manipulation and calculate the wanted information. -
What happened?
When selection a new time slice the panels do their queries and this takes some time. However the panel that uses the other panels as its source doesn’t wait for the source panels to all complete their updates. And then displays the “wrong”/“old” information. An additional Refresh solves the issue gives the right information. -
I expected the “slave”/“child” panels to wait for the “master”/“parent” panels to complete their queries and transformations before they update their information. -
That is very large JSON file -
No -
No
