hi all, before i get too far down the road, thought i would ask. i have several pi machines that i want to be able to trace the logs and alert on. can i put all of those in one cloud stack?
thanks!
thanks!
Hi @boilermanc84 ! Yes, you can send metrics, logs, traces, and profiles from multiple hosts and services for storage in the same Grafana Cloud stack. You can find the instance details, such as remote_write
endpoint and instance ID, in your account portal. I recommend setting the hostname in the agent / collector / remote_write
config so that similar data can be differentiated by host.
Have you decided how you will send data to Grafana Cloud yet? There are quite a few options!
