Grafana Cloud APIs to consume logs and metrics
I am using Grafana Cloud to store my device metrics and logs and now I want that data to my front-end app, so my question is like how I can consume that data so is there any APIs are available?
I’ve gone through the docs but no luck, all the documentation are available to push data and manage instances :neutral_face:
Hi @mineshp !
There are two different API systems to work with for your Grafana Cloud environment:
First, the Grafana Cloud API which is used for creating API keys for your managed instances (Prometheus, Loki etc) and for managing resources at the organization level such as creating a stack or restarting the Grafana instance.
Secondly, the Grafana HTTP API which is used for working with the hosted Grafana instance resources, such as creating a dashboard or setting folder permissions.
Note there are APIs for the other Grafana projects as well:
In your account portal, if you select the “details” tab for your Prometheus, Loki, and Tempo instances there will also be query endpoint details.
Hope that helps!
Thanks @Melody :clap:, it helped a lot
