10.1 on the grafana cloud -
Get API URL endpoint. -
I have a synthetic monitor in a free Grafana account, and I have a service account created with read-only permissions, I can’t seem to find the API URL to pull metrics out of Grafana, how do I do that? -
What happened?
Can’t seem to find it. -
Read through documentations but can’t seem to find anything.
I think its similar to this : How to access Grafana hosted-Prometheus API directly? - #3 by tanmaybhat24.
Please refer once and let us know if it helped.
Thanks, that worked. Also If i want to create checks on grafana synthetic monitory using code and github actions, is this the very endpoint i’ll have to query?
No, this endpoint for querying only metrics stored inside grafana cloud.
