Hi Team,
I want to monitor the url of my application - up or down…
Can you please suggest which plugin I can use?
Note: we are not using any telegraf agents to configure under telegraf.config file… we are using only plugins.
Also pls confirm the panels which supports url monitoring
@ajaypabba if you’re using grafana cloud, you might be interested in synthetic monitoring:
It’s available with the free version of grafana cloud - Pricing | Grafana Labs
If you’re using grafana on-prem, some users install the synthetic monitoring app on their local version of grafana to view the data there:
