I am new with Grafana and Prometheus.
I want to manage metrics on my API in order to expose it on Grafana. I created a new endpoint for that with a basic authentication. It is working fine on Postman and on web browser.
Now my question is how can I connect my API metrics/endpoint with Grafana ?
Because I have an error (invisible) when I try to create new data source in Grafana.
If you want, you can find attached, a screenshot of the error and my JS file.
Thanks.
'use strict';
* PACKAGES
const Register = require('prom-client').register;
const Counter = require('prom-client').Counter;
const Histogram = require('prom-client').Histogram;
const Summary = require('prom-client').Summary;
const ResponseTime = require('response-time');
* VARIABLES
const numOfRequests = new Counter({
help: 'Number of requests made',
labelNames: ['method']
const pathsTaken = new Counter({
help: 'Paths taken in the app',
labelNames: ['path']
const responses = new Summary({
help: 'Response time in millis',
labelNames: ['method', 'path', 'status']
module.exports.startCollection = function () {
require('prom-client').collectDefaultMetrics({
remote_write: { url: ''}
module.exports.requestCounters = function (req, res, next) {
if (req.path !== '/metrics') {
numOfRequests.inc({ method: req.method });
pathsTaken.inc({ path: req.path });
next();
module.exports.responseCounters = ResponseTime(function(req, res, time) {
responses.labels(req.method, req.url, res.statusCode).observe(time);
res.setHeader('X-Response-Time', time);
module.exports.injectMetricsRoute = function (app) {
app.get('/metrics', (req, res) => {
res.set('Content-Type', Register.contentType);
res.end(Register.metrics());
