so basically this is my very first touchpoint with grafana, but also after searching with different keywords online and the community, I was not able to find a solution.
My Hardware:
1x Raspberry Pi 3 with ZWAVE and homebridge running
2x Raspberry Pi Zero with Pihole installed for redundancy
1x Raspberry Pi 3B+ with Plex and nextcloud running
1x Raspberry 3B with CC2531 module and homebridge running
All of them will be in a custom made case together.
I want to be able to see at the end on one window:
- Uptime, CPU/Memory Usage and temp from each PI separately
- Both Pi-Holes with something like this: https://www.reddit.com/r/pihole/comments/bnbryr/my_pihole_dashboard_in_grafana/
- Nextcloud Status with something like this:
https://github.com/xperimental/nextcloud-exporter - Getting some basic information from homebridge displayed like is homebridge running, stopped etc.
Is it possible to combine these information in “one” grafana window even if the source is located on different PI’s?
Thx in advance!
