Grafana v8.0.4 -
Alerting based on MSSQL data -
Same way as in version v7.0.3 -
What happened?
Upgraded Grafana from version v7.0.3 to v.8.0.4.
After the upgrade our MSSQL based alerts returns the following exception if no data returned from SQL server:
error:“request handler failed to convert dataframe “results” to plugins.DataTimeSeriesSlice: input frame is not recognized as a time series” -
Our existing panels should work in the same way as before. If no data returned from SQL it should show that. -
This is the Query:
SELECT $__timeGroup(transactionDate, '10m', 0) as time, COUNT(*) as VALUE
FROM xxxx.dbo.xxxxx A
WHERE $__timeFilter(transactionDate)
AND result <> 0
GROUP BY $__timeGroup(transactionDate, '10m')
ORDER BY time asc
And this is the alert rule:
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
in the UI\Alert Rules: Execution Error: request handler failed to convert dataframe “results” to plugins.DataTimeSeriesSlice: input frame is not recognized as a time series
I would appreciate any help.
Thanks a lot!
