I would like to create some alerts on my grafana website, but I can’t achieve to do it ![]()
as you can see, it says “No data”, even my query seems good (a point every 5min), and the alarm display well.
What am I doing wrong ?
Thanks
Nobody have this problem ?
I tried another dashboard and it’s the same
thanks
Object
firing:false
state:“no_data”
conditionEvals:“false = false”
timeMs:“9.599ms”
logs:Array[2]
0:Object
message:“Condition[0]: Query Result”
data:null
1:Object
message:“Condition: Eval: false, Query Returned No Series (reduced to null/no value)”
data:null
Hi @dureiken, can you also post how your query looks like?
@zigobos In your example it seems like the issue is that your condition checks interval for which there really aren’t any data. The part query(A, 5m, now) means it will take last value from time range between now-5min and now and from your graph it looks like there is no data point since ~ 16:20. Try changing the interval to something like query(A, 5h, now-4h) or something like that so it hits the range when there are values. Though ideally to test the alerts you would do it on datasource which has some current values.
In @dureiken example it seems there should be data in the specified interval query(A, 1h, now-5m) but would be a good idea to look at the returned data from the query and check if there really are data points for that interval just to be sure.
Thanks for your help
I think the problem comes from UTC time
Because I’m UTC+2, and I can’t choose now -2h, now -3h for example.
Could I change it manually ?
edit : yes it works with 24h, now -1h
Thanks
@dureiken If you mean inside the query(), when you click on a param you can write the params value manually as it is a text input, you do not have to select it from the drop down menu. Though I am not sure if the timezone difference should create such problem.
ok it was that
with now-4h,now-2h it seems to work
thanks a lot
Thank you for this answer! That was what I was doing wrong too.
One possible cause is the format you use for query. If you set it as a table, try set the “Format as” to Time Series.
Or you could try to pause and restart the alerts.
I hope that helps.
