I’m trying to explain an odd set of alerts from a panel on my grafana dashboard. High level notes and more info below:
- My query aliased “failure” does not have any data
- My alarm will set state to OK when No Data is available
- This alarm is alerting multiple times over a 2 day window (despite the settings above)
- This alert is claiming a query value of “20” for all alerts (not justified in data)
Assuming there is no data for an query, and the alarm allows no data, I would not expect these alerts. And if they were accurate alerts I would expect a variable failure value given variable usage.
Can anyone help explain this behavior?? Any help is appreciated
See screenshots:
See Test Rule results:
"firing":false,
"state":"ok",
"conditionEvals":"false = false",
"timeMs":"37.435ms",
"logs":[
"message":"Condition[0]: Query",
"data":{
"from":1671804237126,
"queries":[
"refId":"A",
"model":{
"datasource":{
"type":"graphite",
"uid":"000000008"
"hide":false,
"refCount":0,
"refId":"B",
"target":"aliasByNode(stats….failure, 7)",
"textEditor":false
"datasource":{
"id":8,
"name":"graphite"
"maxDataPoints":1500,
"intervalMs":200
"to":1671804537126
"message":"Condition[0]: Query Result",
"data":{
"fromDataframe":true,
"series":[
"message":"Condition: Eval: false, Query Returned No Series (reduced to null/no value)",
"data":null
